Fastest way in PASM.... ?challenge?
This started as a quick thing, but became an afternoon obsession. And I'm hoping smarter people can come up with creative solutions.
I want to create a function that "divides" a number by shifting. But when it does, I want it to round the LSB up or down as needed. In normal math: 5 / 2 = 2.5. In integer math, that results in 2, but I would want it to round up to 3.
I want the function be to divide any positive integer by one or more shifts (divide by any power of 2).
Can anyone come up with anything faster than div3?
They were tested like this:
PUB div1 (val, sh) | v 'executes in 3056 cycles RETURN ((v := (val >> (sh - 1))) & 1) + (v >> 1) PUB div2 (val, sh) 'executes in 2864 cycles RETURN (val >> sh) + ((val >> (sh - 1)) & 1) PUB div3 (val, sh) 'executes in 2704 cycles RETURN ((val & (|< (sh - 1))) + val) >> shI have them in methods to speed up testing, though in the final product I will likely pull them out to speed them up further.
start := cnt div3(248, 4) time := cnt - start - 368
I put question marks around the "challenge" because now I realize, it may not be a challenge for some :-P . It's no fun if the first reply is the best method.
Any faster ways (seems unlikely)?
Same as Dave's solution, but it is slower....
Jonathan
For SPIN, the way I'm using it, there shouldn't ever be a situation where 0 shifts would occur. Just assume one shift or more.
'Didn't time it; Dave's might be faster.
So here's my question: given this observation, are there any cases where the present first-to-shift semantics are better than last-to-shift? (Disclaimer: I realize that with a one-clock barrel shifter, "first" and "last" are nonsense terms, but it's still useful to think of the carry as bit32 or bit-1 of an extended, 33-bit destination register.) I'm just trying to fish for why Chip designed these instructions the way he did.
Your guess is as good as mine but it would seem rather odd if this was a deliberate decision.
Then again, why would it work with normal ALU based instructions? Different paths? Or not enough space?
In any event, if any of this is true, it would seem that last-to-shift would have been just as easy to implement as first-to-shift.
And this natively supports 0 shifts. So we can drop the TJZ (for the shift count check) and that is faster and smaller.
@kuroneko
No, that was a fairly interesting discussion. I personally thought about Phil's idea about why must the carry be filled by bit 0 or 31, why can't it be the last bit shifted.
