Sending Bytes?
So I am trying to 'code my code' and add values to certain numbers before they send so that the various sensors willhave different values and then I can know what values I have. I am wondering if anybody can tell me if I am asking too much from the basic stamp or the propeller. PS- I am using Xbee transceivers
BASIC STAMP
n the propeller
Also, the propeller board is a spinneret. Any help is greatly appreciated!
BASIC STAMP
' {$STAMP BS2}
' {$PBASIC 2.5}
BDistance VAR Word
LDistance VAR Word
RDistance VAR Word
CDistance VAR Word
Compass VAR Word
signal VAR Word
BDistanceA VAR Word
RDistanceA VAR Word
CDistanceA VAR Word
CompassA VAR Word
HIGH 6
DO
SERIN 6,84, [signal]
IF signal = "L" THEN
SERIN 6,84, [DEC LDistance]
DEBUG HOME, DEC LDistance, " inches left"
SEROUT 13,84, [DEC LDistance]
PAUSE 250
ELSEIF signal = "R" THEN
SERIN 6,84, [DEC RDistance]
DEBUG HOME, CR, DEC RDistance, " inches rt"
RdistanceA = Rdistance + 148
SEROUT 13,84, [DEC RDistanceA]
PAUSE 250
ELSEIF signal = "C" THEN
SERIN 6,84, [DEC CDistance]
DEBUG HOME, CR,CR, DEC CDistance, " inches front"
CDistanceA = CDistance + 296
SEROUT 13,84, [DEC CDistanceA]
PAUSE 250
ELSEIF signal = "B" THEN
SERIN 6,84, [DEC BDistance]
DEBUG HOME, CR,CR,CR, DEC BDistance, " inches rear"
BDistanceA = BDistance + 444
SEROUT 13,84, [DEC BDistanceA]
PAUSE 250
ELSEIF signal = "s" THEN
SERIN 6,84, [DEC Compass]
DEBUG HOME,CR,CR,CR,CR, DEC Compass
CompassA = Compass + 1000
SEROUT 13, 84, [DEC CompassA]
PAUSE 250
ENDIF
LOOP
n the propeller
CON
_clkmode = xtal1 + pll16x 'Use the PLL to multiple the external clock by 16
_xinfreq = 5_000_000
Baud = 9600
OBJ
bs : "BS2_Functions" 'BS2 Libraries
STR : "STREngine.spin" 'A string processing utility
Var
long number
long distanceL
long distanceR
long distanceB
long distanceC
long compass
Pub main
bs.start(25,30)
repeat
number := bs.SERIN_char(25,9600,0,8)
if number => 0 and number =< 147 'Left
bs.serout_dec(31, number, Baud, 1, 8) 'debug
bs.Debug_Char(13)
distanceL := number
'STR.numberToDecimal(distanceL, 3)
elseif number => 148 and number =< 295'Right
distanceR := number - 148
bs.serout_dec(30, distanceR, Baud, 1, 8)
bs.Debug_Char(13)
distanceR := number
'STR.numberToDecimal(distanceR, 3)
elseif number => 296 and number =< 443'Front
distanceC := number - 296
bs.serout_dec(30, distanceC, Baud, 1, 8)
bs.Debug_Char(13)
distanceC := number
'STR.DecimalTonumber(distanceC)
elseif number => 444 and number =< 591' Back
distanceB := number - 444
bs.serout_dec(30, distanceB, Baud, 1, 8)
bs.Debug_Char(13)
distanceB := number
'STR.DecimalTonumber(distanceB)
elseif number => 1000 and number =< 1360 'Compass
compass := number - 1000
bs.serout_dec(30, compass, Baud, 1, 8)
bs.Debug_Char(13)
compass := number
'STR.DecimalTonumber(compass
Any IO-pin of the propeller can be used for serial datatransmission
In your code above you are using the propeller-basic-stamp-functions. They are a quick entrance but they are quite limited (like the basic stamp itself compared to the propeller-chip).
Simply use the IO-pins 31,30 for the serial connection together with the FullDuplexSerialPlus-object (shortna,e FDX+) which can be found in the propeller-tool library
You don't need the str-engine to tie everything together before sending with FDX+ because FDX+ has methods for sending
- single characters
- decimal values
- strings
keep the questions coming
best regards
Stefan
