What is the easiest way to do a 3D model of a pcb?
I use Protel Advanced PCB V3.x which is quite old (circa 1995).
I would like to do some 3D representations of some of my pcbs. What is the easiest and cheapest (free) way? (software etc).
Seriously, you can probably import your designs into another package that does 3D, like the Pulsonix demo. Eagle might be worth trying, also; I think that has 3D capability. I could import your designs into Pulsonix and let you have the images.
I just saved this 3D image of one of my boards. I didn't put any effort into making the parts look realistic in a 3D design program. I can rotate the image, zoom in and out, and do clever stuff like showing drill holes and zooming into them.
If you're using Protel/Tango you could give it to someone with Altium Designer to generate the 3D for you
Of course, if you wanted a professional quality model, you could (cough) hire me to design one (cough)
I saw Google Sketchup should work, but I failed to find hardly any 3d parts. Are there 3d parts available for diptrace? (simple parts.. ICs, pin headers)
I´ve used it for a couple of designs. Now that I have used it for a while I have started to wonder why hobbyists would ever need anything that costs money.
/Johannes
Exactly Leon. My pcbs are simple and I would just like a simple 3d program to make a simple representation so I can show the stacking and plugging capability. A simple and approximate representation of my pcbs is all I require for now, so a simple 3D program (free) is all I require. I am happy with my (legal) Protel, bugs and all, at least for now.
So I need the following 3d objects: 44pin QFP, Pin headers, both male and female, xtal hc49us, and to create a pcb with holes. That is pretty much it because the resistors, caps, etc are not required, at least for this exercise.
Considering how my avatar is composed of electrical components, I haven models of all of them, and a QFP propeller chip model. I can send them to you if you want to use them.
I looked at the various options. However, I cannot seem to find a simple example of how these models are put together. SUrely there is a library of fairly standard parts (ics, resistors and caps at least) that can be placed on a pcb to produce a basic 3d model. I have seen lots of pics of them. Isn't there a 3d program that I can just add the blocks (ics, etc) to a pcb base and simply do this???
In the 3D view section I was able to create a pcb and place components on it from the component pane. But so far I have not worked ot how to add those components from the library - I can edit them, but not copy them onto the pcb. Otherwise, this looks simple enough, and lots of components in the library to make what I need. As I said, I am only after a simple 3D representation, not accurate (at least for now).
I might have another link. I will respond as soon as I can find that link.
Found the link! try here
