DSP : Flange Effect / Comb Filter - Anyone tried it on the Propeller?
I've seen mention and implementation of several DSP and filtering techniques here, anyone worked through a comb filter or flange effect?
I need to apply it dynamically to a 22khz 16-bit pcm stream.
This technique uses a varying sampling rate which is a tad tricky for a signal that's already sampled at a fixed frequency... You'd have to fill a buffer at a fixed rate and pull samples out at a varying rate and feed to a DAC run by the same varying clock perhaps? (and prevent the buffer emptying or over-filling).
I don't know anything about the details. Take a look at it to find out if this device would be suitable for you
keep the questions coming
best regards
Stefan
