Trying to decide on what problem to tackle
I guess this can be better titled as "HOW to tacke this problem...." rather than the garbage I posted it as..... anyhow
Working again on the new version of my tester. I want a "Probe Mode" so that single-ended assemblies can be plugged into a mating fixture, and a grounded probe is touched to one of the bare wires, and a pin number comes up on the display. I would like to access this info in the "Point" method, by using the "TP" variable as some kind of step counter. Here is my list of needs/problems:
1 - This main program is only a template. I want to be able to change one area quickly, so that this unit can test multiple assemblies without having to re-write all of the code. If modifications could be made in less than a minute or two, It would allow the prototyping dept. to have one for new assembly design and checking, and all my time would not be used up with every new assembly that comes through here.
2 - Some connectors are labeled by letters, some by numbers. Large pin count connectors go up to "Pin Z", then cycle to "Pin AA", and continue on. My hardware and code supports 64 test points.
3 - DAT blocks for this purpose are confusing me. If one assembly uses numbers, and the others are letters, wouldn't this change the data length per test point, thus making it difficult to predict where "TP A" ends, and "TP B" begins in one program, versus "TP 1" and TP 2" in another, using the same template program?
4 - Lookup would be super simple, but I am under the assumption that you cannot store anything but numbers in this fashion, and ASCII code would be a pain to do a conversion on by hand for 64 test points, every time I need to modify for a new assembly.
Here is a copy of the code I am using in my output file
VAR Byte Xpos Byte Ypos Byte RowCnt Byte BlankCntA Byte BlankCntB OBJ text : "tv_text" DAT RevA byte "0.000", 0 Assy byte "Sample", 0 FIX byte "FX-0000", 0 { TP1 byte "1", 0 TP2 byte "2", 0 TP3 byte "3", 0 TP4 byte "4", 0 TP5 byte "5", 0 TP6 byte "6", 0 TP7 byte "7", 0 TP8 byte "8", 0 TP9 byte "9", 0 TP10 byte "10", 0 TP11 byte "11", 0 TP12 byte "12", 0 TP13 byte "13", 0 TP14 byte "14", 0 TP15 byte "15", 0 TP16 byte "16", 0 TP17 byte "17", 0 TP18 byte "18", 0 TP19 byte "19", 0 TP20 byte "20", 0 TP21 byte "21", 0 TP22 byte "22", 0 TP23 byte "23", 0 TP24 byte "24", 0 TP25 byte "25", 0 TP26 byte "26", 0 TP27 byte "27", 0 TP28 byte "28", 0 TP29 byte "29", 0 TP30 byte "30", 0 TP31 byte "31", 0 TP32 byte "32", 0 TP33 byte "33", 0 TP34 byte "34", 0 TP35 byte "35", 0 TP36 byte "36", 0 TP37 byte "37", 0 TP38 byte "38", 0 TP39 byte "39", 0 TP40 byte "40", 0 TP41 byte "41", 0 TP42 byte "42", 0 TP43 byte "43", 0 TP44 byte "44", 0 TP45 byte "45", 0 TP46 byte "46", 0 TP47 byte "47", 0 TP48 byte "48", 0 TP49 byte "49", 0 TP50 byte "50", 0 TP51 byte "51", 0 TP52 byte "52", 0 TP53 byte "53", 0 TP54 byte "54", 0 TP55 byte "55", 0 TP56 byte "56", 0 TP57 byte "57", 0 TP58 byte "58", 0 TP59 byte "59", 0 TP60 byte "60", 0 TP61 byte "61", 0 TP62 byte "62", 0 TP63 byte "63", 0 TP64 byte "64", 0 } PUB Start(TVPin) ''Start TV Cog text.start(TVPin) Header PUB TPIndex | Index, TPNo TPNo := lookup(Index: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10,{ ' Lookup table for TP data }11, 12, 13, 14, 15, 16, 17, 18, 19, 20,{ }21, 22, 23, 24, 25, 26, 27, 28, 29, 30,{ }31, 32, 33, 34, 35, 36, 37, 38, 39, 40,{ }41, 42, 43, 44, 45, 46, 47, 48, 49, 50,{ }51, 52, 53, 54, 55, 56, 57, 58, 59, 60,{ }61, 62, 63, 64) PUB Header '' Base Screen text.str(string($0B, 01, $0C, 03, "┌────────────────┬─────────────────────┐")) ' Output Screen art text.str(string($0B, 02, $0C, 03, "│ │ Failures: │")) text.str(string($0B, 03, $0C, 03, "│ ├─────────────────────┤")) text.str(string($0B, 04, $0C, 03, "│ │ │")) text.str(string($0B, 05, $0C, 03, "│ │ │")) text.str(string($0B, 06, $0C, 03, "│ │ │")) text.str(string($0B, 07, $0C, 03, "│ │ │")) text.str(string($0B, 08, $0C, 03, "│ │ │")) text.str(string($0B, 09, $0C, 03, "│ │ │")) text.str(string($0B, 10, $0C, 03, "│ │ │")) text.str(string($0B, 11, $0C, 03, "│ │ │")) text.str(string($0B, 12, $0C, 03, "└────────────────┴─────────────────────┘")) text.str(string($0A, 02,{ ' Assy Flag }$0B, 01,{ }$0C, 03,{ }"Assy: ")) text.str(@Assy) text.str(string($0A, 02,{ ' Display fixture }$0B, 04,{ }$0C, 03,{ }"Fixture:")) text.str(string($0A, 02,{ ' Display fixture number }$0B, 05,{ }$0C, 03)) text.str(@Fix) text.str(string($0A, 13,{ ' Display rev }$0B, 12,{ }$0C, 07,{ }"N.A.T.S. v")) text.str(@RevA) Xpos := 18 ' Cursor Position for reports Ypos := 3 RowCnt := 0 PUB Testing ''Test in progress text.str(string($0A, 05,{ ' In-Process msg }$0B, 10,{ }$0C, 06,{ }" Testing ")) PUB Pass ''Pass message text.str(string($0A, 05,{ ' Pass flag }$0B, 10,{ }$0C, 04,{ }" PASS ")) PUB Fail(FailCnt) ''Failure message text.str(string($0A, 02,{ ' Failure count flag }$0B, 07,{ }$0C ,03,{ }"Fails= ")) text.dec(FailCnt) text.str(string($0A, 05,{ ' Fail flag }$0B, 10,{ }$0C, 01,{ }" FAIL ")) RowCnt := 0 PUB Short (TestPoint, FailCnt) ''Short message Placement(FailCnt) ' Set cursor for error text.str(string($0A, 05,{ ' Lg. Short Flag }$0B, 10,{ }$0C ,01,{ }" SHORT ")) text.str(string($0A)) ' Go to position text.out(Xpos + RowCnt) text.str(string($0B)) text.out(Ypos) Ypos := Ypos + 1 text.str(string($0C, 06,{ ' Sm. Short flag }"S-")) text.dec(TestPoint) PUB Open (TestPoint, FailCnt) ''OPEN message Placement(FailCnt) ' Set cursor for error text.str(string($0A, 05,{ ' Lg. Open Flag }$0B, 10,{ }$0C, 01,{ }" OPEN ")) text.str(string($0A)) ' Go to position text.out(Xpos + RowCnt) text.str(string($0B)) text.out(Ypos) Ypos := Ypos + 1 text.str(string($0C, 06,{ ' Sm. Open Flag }"O-")) text.dec(TestPoint) PRI Placement(FailCnt) '' put in place a display overflow plan. resume test key, '' clean the report area, then continue test if FailCnt == 9 ' If end of Column1 is found Ypos := YPos - 8 ' Bring cursor back up to the top RowCnt := 1 ' Increment row counter variable Xpos := XPos + 4 ' Move to next row if FailCnt == 17 ' If end of Column2 is found Ypos := YPos - 8 ' Bring cursor back up to the top RowCnt := 2 ' Increment row counter variable Xpos := XPos + 4 ' Move to next row if FailCnt == 25 ' If end of Column3 is found Ypos := YPos - 8 ' Bring cursor back up to the top RowCnt := 3 ' Increment row counter variable Xpos := XPos + 4 ' Move to next row Pub Counter(StepCnt) '' Test step counter text.str(string($0A, 02,{ ' Step Number }$0B, 02,{ }$0C, 03,{ }"Step: ")) text.str(string($0A, 06,{ ' Clear Old Numebr }$0B, 02,{ }$0C, 03,{ }" ")) text.str(string($0A, 06,{ ' Show Step Number }$0B, 02,{ }$0C, 03)) text.Dec(StepCnt) ' Step number shown text.str(string($1)) PUB Point(TP) text.str(string($0A, 24,{ ' Probe Flag A }$0B, 04,{ }$0C, 03, { }"Probe:")) text.str(string($0A, 24,{ ' Probe Flag B }$0B, 06,{ }$0C, 05, { }" TP- ")) text.str(string($0A, 24,{ ' Disp. Point Number }$0B, 06,{ }$0C, 05,{ }" TP- ")) text.str(string($0A, 27,{ ' Disp. Point Number }$0B, 06,{ }$0C, 05)) text.Dec(TP) ' placeholder TP numebr (Step number copy for development) PUB nerp ''Flag for debugging text.str(string($0A, 05,{ ' Disp. break Flag }$0B, 09,{ }$0C, 06,{ }" NERP ")) waitcnt(clkfreq * 2 + cnt) PUB BinOut( BinDat, Bits) ''Output binary status of tester inputs to TV (debug mode) text.str(string($0A, 04,{ ' Display position for bin data }$0B, 12,{ }$0C, 05)) text.bin(BinDat, Bits) ' Actual Binary Data PUB Clean '' Clean up display for next run BlankCntA := 18 ' Clear failure notification area BlankCntB := 3 repeat 8 Repeat 21 text.str(string($0A)) text.out(BlankCntA) text.str(string($0B)) text.out(BlankCntB) text.str(string($0C, 03, " ")) BlankCntA := BlankCntA + 1 BlankCntB := BlankCntB + 1 BlankCntA := 18 text.str(string($0A, 02,{ ' Clear FailCount area }$0B, 07,{ }$0C ,03,{ }" ")) text.str(string($0A, 05,{ }$0B, 09,{ }$0C, 03,{ }" ")) ' Clear notification area Xpos := 18 ' Reset cursor position Ypos := 3 RowCnt := 0
I'm really sorry but I did not understand what you want to do.
If you have explained more details in another thread please provide a link to it. Of if not please explain what your project does.
From the basic principle Is the purpose of your canle-tester to check
if PIN "A" of connector-1 is connected to PIN 27 of connector-2
if PIN "Z" of connector-1 is connected to PIN 12 of connector-2
if PIN "AA" of connector-1 is connected to PIN 45 of connector-2
etc.?
You wrote something about probing. In the code you posted there is a lot of output to a TV-screen
but almost nothing about how the probing/testing is done.
You want to change "an area quickly" which area of what? area of code?
what are the typical changes? Can you give some examples?
is there a regular pattern in the changes?
Can you please provide a simple, a medium complex and a most complex example of how wires are named and what must be changed
not as code but as a written description.
How does a typical screen of a test passed everything alright and how does a typical screen look like where failures are in the cable?
keep the questions coming
best regards
Stefan
Dave
This is my full base theory of operation:
Yes. this is an auto-tester that has a data pin from a TPIC6595 connected to a data pin of a 74HC165 to make the resulting connection an I/O. this is repeated for each of the 8 data pins on each IC, then the TPIC's and 165's multiplexed to 8 pairs to give me a total of 64 I/O's.
The main program cycles outputs to the TPIC6595, one point at a time. there is an array of variables in the main program that is compared to the data streamed in from the 74HC165's, and does some math to determine if the data found is an open, short, or correctly wired.
A feature that is heavily requested by the production floor is an extra mode in the tester where we are able to connect a cable that has a connector on one end, bare wires on the other via an adapter that is made just for the product in question. This will let them be able to determine if the wire's color is correct for single-ended assemblies. I have a switch and the basic idea for putting the tester into this alternate mode.
I would like one data section for Test point labeling, like I did for the "Expected cable information". Like I said earlier, Lookups I believe only handle numbers. I can trick it using ASCII codes in case I want letters, or even color names, but this is cumbersome. Numbers are no big deal, because in previous versions of this tester, I was able to tie it in with step numbers, and all was good. This is a clunky way of doing it, and I am looking for something better. If I were to use a DAT section (like the area for Fixture number, assembly number, and system Rev information), wouldn't that case problems if I do a "Raw access" to the data because in one product file the test point would be labeled "1", and in another it could be called "A", or in another called "Blue", creating a different offset, thus giving me garbage on the display?
Here is the full source up to this point. I plan on adding the test point methods to the top level file as soon as I get this issue figured out.
AutoTester MK2 v.001 - Archive [Date 2011.07.26 Time 09.48].zip
I'll start coding all this in after a little bit, and let ya know if this does the trick. Thanks Dave.
congrats to your ideas. You took the time to understand the problem and made good suggestions.
best regards
Stefan
I wrote this into my open and short reporting methods, and from the first looks, it was changing the wire location flags accordingly. Thanks so much for the suggestion
I defined MAX_CHARS to be the maximum size of each label, not including the terminating null. Therefore, the string address should be computed as @labels + (MAX_CHARS+1)*(TestPoint-1). I'm assuming TestPoint has values from 1 to 64. If TestPoint has values from 0 to 63 then the "-1" should not be used. Similarly, if you define MAX_CHARS to include the null then the "+1" should not be used.
Each entry must contain the same number of bytes in the table. In my example, I padded out with MAX_CHARS zero-bytes for single-byte names, and (MAX_CHARS-1) for two-byte names. If you intialize the table with multi-byte labels you need to adjust the number of zeros accordingly.
Yeah I looked that up while you were editing your post, and saw pretty much the same thing in the prop book. I am going to be doing that comparison once inside of a loop, so it should not take up any more memory than making a variable out of it, and referencing that.
But, all that aside, I got it working. Thanks again Dave. And still, I learn piles of info from folks in this forum. Truely everyone here is ridiculously helpful. I just hope that someone else out there is learning from my blundering, and someday in the near future I will be able to give a little back.
