AT24C512 replacement
I know this has been covered before. I've been using the AT24C512 on all my Propeller boards for years.
I know the part is obsolete. It looks like they've finally run out of them everywhere.
What it the best replacement to use that has the same protocol and structure?
Is the M24512 a good choice?
Thank you for your help.
Jim
Jim
Actually you inspired me. They aren't available at Mouser, Digi-Key, etc. But I did locate some at a place called onlineComponents.com. Anyone familiar with them?
It sounds like I should either buy a bunch now, or switch to a different form factor.
Thanks for the help.
Jim
I'll probably switch to the wider BW part for future boards.
Jim
