Welcome to the forum.
There are only whole numbers in Spin. Everything is a signed integer. For example if you divide five by two you will get two.
What exactly are you trying to do?
Thank you Heater - I think that may explain a lot of my issues..
I was trying to test some trig functions, for example cos(111) should = -0.358... It kept returning 0, so I thought it was just a broken function.
Based on what you are saying I will need to re-evaluate my algorithms - I am not sure yet if it will work without at least some decimal values.
Except I was a bit wrong. You can use floating point values as constants in Spin or to initialize variables. But the operators +-*/ etc won't work properly with them.
There is a very nice floating point package with all trig functions in the object exchange. Look for F32.
Thanks so much for your help!
