555 Freq & Duty component calculator
Hey, I thought this was a real good find! Every other 555 calculator I've found works the other way-round.... enter component values and it'll give you F & D.
http://www.daycounter.com/Calculators/NE555-Calculator.phtml
Enter your desired frequency and duty cycle, and p-tooey, it'll give you the components required
Thanks for sharing this!
It works!! I built the oscillator last night with the values calculated. I checked the values in my caculator first, and they lined up perfectly.
I didn't have a 5.061k resistor, but a 4.7k was plenty close enough.
One more note: The cap value is an input as well. So you can tweak the cap value to offset your resistor values into something a little closer to "Standard" stuff. For example, 50kHz might use a 0.2ohm and 234ohm resistor with a 10uF cap, BUT by changing the cap to 0.001uF, the calculated resistors are more reasonable.
Enjoy!
Thanks for validating this in hardware. I was looking for a calculator like this last week. I'm glad I procrastinated. Thanks again. :-)
