Propeller tachometer (in the field this time)
Take 4. Propeller tachometer under field conditions (in the car, not on a bench simulator this time)
http://www.youtube.com/watch?v=wkKVYTF8cgY&feature=mfu_in_order&list=UL
Now I have to program out that pesky leading zero for RPM readings less than 1,000.
Very cool and well done. Good luck with your leading zero.
Bruce
Have you posted your code yet to the objects library? I'm trying to do something similar and would like to check it out. Thanks!
Does the RPM signal actually depend on the number of cylinders? I thought that RPM in most cars is just equal to the frequency of the signal to the tach i.e. 4000 Hz signal = 4000 RPM.
