ViewPort Serial Problem
I have a Propeller Rapid Prototyping problem that uses a serial interface. I am using a USB to Serial Dongle for communication. The Propeller Tool V1.3 works without problems. Recently purchased the Latest Viewport Debugger but it does not work with the Serial interface. It will 'Find and Reset' the board, but gives and error when I start the debugger. The target program is tutorial 1 that comes with the Viewport. The serial port is identified properly and I have set the baud rate to 115K.
Message is
Failed to configure on COM4
Verify that your device:
* has a good power supply
* is connected with a good USB cable
* is programmed with the right clock settings
* uses the conduit.share function
Make sure the port and baud settings are correct
All these items are OK.
Any suggestions?
Message is
Any suggestions?
