ChronoDot with the Prop? — Parallax Forums
FranklinFranklin Posts: 4,747
edited 2011-07-21 18:00 in Propeller 1
I have a ChronoDot (DS3231) and am having trouble getting it to work with the Propeller. I have clock on 28, data on 29, pullups (10K) to 3.3 on both. I downloaded the DS1307_RTCEngine object and tried it with no luck. I also tried the i2cObject and it is not found. I tried both the default )xD0 and the ChronoDots 0x68. Is there something I'm missing? It works fine on an Arduino so I know the device is working.
  • blittledblittled Posts: 683
    edited 2011-07-21 05:01
    I had a similar problem with another board only to find out the I2C address of the device needed to be multiplied by 2 since the lowest bit is used for read/write. Try using address D0 and see if it works.
    edited 2011-07-21 07:09
    I attached some code I worked on last Sept using the ChronoDot.
    I modfied Kye's object - It handles 12hr or 24hr mode.
    I used 10k pullup resistors on the SDA/SCL pins.
    You can strip out the code for the LCD...
    EDIT: Revised code to remove debugging in DSRTC_driver.spin
    In one demo program I was using pins 26 & 27 - don't recall why
    _clockDataPin = 27 '29
    _clockClockPin = 26 '28
    First off thanks for all who helped and ron that code was great.
    OK, after trying everything I could think of I thought the problem might be my jumpers or the breadboard so I pulled out a propeller proto board I had with headers on it. I plugged it all together and, what do you know it worked (with $68 < 1) I went back and plugged my new jumpers into the breadboard after movung the propmodule to a different location and it still did not work so I think the module is hosed although it runs most other code just fine. I don't know what is wrong with it but might look at some of the other small prop modules to replace it.
    Thanks for all the help and I now have three or four different clock programs to chose from. :)
