What am i doing wrong?
So im currently trying to problem shoot my transmitting/receiving codes by hardwiring the stamp to propeller board. And im running my program and getting a consistent 96 on the receiver side but it's not the data im sending :blank:
also in the hard wiring im using a 2.2k resistor for the voltage conversion
try it for your self
Propeller code:
BS Code:
Propeller code:
CON 'ClkFreq: 80 Mhz _XINFREQ = 5_000_000 'Adjust the frequency _CLKMODE = XTAL1 + PLL16X 'Adjust the frequency rx = 7 tx = 2 baudRate = 9600 polarity = 1 bits = 8 OBJ bs : "BS2_Functions" 'Basic Stamp 2 library VAR byte number PUB start BS.start(31, 30) repeat number := BS.serin_char(rx, baudRate, polarity, bits) 'receive from BS; Tried to use "BS.serin_dec", but didn't work BS.serout_dec(30, number, baudRate, 1, 8) 'show data received on screen BS.Debug_char(13)
BS Code:
'{$STAMP BS2} '{$PBASIC 2.5} x VAR Word y VAR Word DO PULSOUT 8, 1200 'Sync pulse for the receiver SEROUT 8, 16468, [ $AA, "!", x.HIGHBYTE, x.LOWBYTE, y.HIGHBYTE, y.LOWBYTE ] x = x + 1 y = y + 1 DEBUG ? x DEBUG ? y PAUSE 1000 LOOP
