GPS question
mmoreland
I have a GPS receiver (28501) and have run into a problem attempting to use it with a BS2. Looking through past Forum threads, I see that a number of folks have found that the BS2 doesn't support the SPSTR modifier, but a BS2p does, so I will retire my BS2 and purchase what's needed. Three questions: If all I want from the GPS is date and time, is it possible to reduce or rewrite the code in such a way that the BS2 will work? If not, will any of the four BS2p (esp. I'm thinking of the BS2pe) models work? Can I plug a BS2p into my BOE without a problem?
On the other hand what's the problem with using an RTC chip with a battery backup? The advantage is that the RTC chips will work even if the satellite signal is not available. RTC's are less precise and won't set themselves though.
