$3 Servo Tester
Lots of servo chatter here lately. A useful $3 tool is this handy-dandy 3-mode servo tester. Works like this $15 unit:
http://www.youtube.com/watch?v=KSmRWhTQx6w&feature=related
Mode 1: manual control via pot
Mode 2: center (1500 ms output)
Mode 3: oscillate (1000-2000 ms output)
But it's just $3 on Ebay China http://cgi.ebay.com/ESC-Servo-tester-3-Channels-CCPM-Meter-Checker-4-8-6V-/150618800040?pt=Radio_Control_Parts_Accessories&hash=item2311947fa8
or $4.48 from Hobby King: http://www.hobbyking.com/hobbycity/store/__14774__HobbyKing_Servo_Tester.html
Hack four of those and you can build this robot arm on the cheap! http://www.youtube.com/watch?v=-XChu20hTxU
I am so excited to be coming to the end of the SERVO chapter. Here is my first servo circuit
Cheers....
I already had a Servo tester but a friend of mine at work is now $3 poorer....
http://www.youtube.com/watch?v=UOr4NNKZErM&NR=1
I have learned to love the fleeting smell of magic smoke!
My 7.4V lipo made short work of that poor servo tester. Fortunately I bought several!
6V of AA alkalines might be more forgiving, but that lipo battery had the right battery connector and everything.
I would think, to test a servo, I would like to know it's accuracy, repeatability, speed and strength.
Not just to see it move.
PLUS, they are very entertaining to my two-year old twin girls: they twist a knob and make something move. These testers buy me a few moments of peace!
Correction: turns out I damaged the servo; the servo tester is fine after reverse voltage was accidentally applied. Still not recommended.
Ever since I saw this post months ago, I've wanted to make my own servo tester.
My servo tester doesn't have the knob for adjusting the servo position (which I admit would be nice) but it uses the QuickStart's touchpads to position the servo.
I beleive my version has a few features the $3 version doesn't.
The oscillation period can be adjusted. You can use this feature to see how fast your servos can move.
The end points can both be independently adjusted. The end points affect both the oscillating servos (the travel amount changes as the end points change) and the "static" servo. The static servo's position can be adjusted up to the end points but not past.
The various parameters are displayed on a terminal window. The program doesn't require the QuickStart is connected with a PC because the parameters are also displayed on the LEDs. The parameters are displayed as binary infomation on the LEDs. When all the LEDs are off the static servos are centered (this is also the starting position). The LEDs indicate how far from centered the servos are (in units of 2us). It's a lot easier to read the parameters from the terminal window.
It wouldn't be hard to change the program to output to a LCD, TV or some other display.
I think the main advantage of the QuickStart servo tester over the $3 servo tester is the ability to change the end points. My cheap little HobbyKing servos only move through half their range with pulses ranging from the standard 1000us to 2000us.
If you already have a QuickStart then this servo tester is free. Otherwise for $25 you can buy a servo tester that's smart enough to control a robot.
IMHO, these testers are so handy and cheap that everybody oughtta have one on their bench and ready to go. Duane, PM me your address and I'll mail you one free for all the wonderful things you do here in the Forum!
Yes, but part of this exercise, besides showing myself I have the will power to resist at least one of the great bargains you post, was to show off the QuickStart board. I'm afraid you're right about it getting repurposed to something else (though it wont be a servo reverser
I'll take you up on your free servo tester. Thanks.
Do you have a QuickStart board? If not, I'll send you one of mine. I usually keep a couple within arms reach. They're so easy to use to test out new devices (like the $4 ultrasound sensors you pointed out that I couldn't resist). It's really handy to have the board powered by the same USB line used to program it.
Well, $2.18, but free ship. Christmas comes early (or very late).
http://www.ebay.com/itm/Brand-New-Blue-CCPM-Servo-Consistency-Master-Servo-tester-S812-/261174258117?pt=US_Radio_Control_Control_Line&hash=item3ccf32e9c5
