ColorPAL Application
New to the whole BS2 concept, but after some research I couldn't find any info on how long it takes the ColorPAL to sense the color of an object. It seems that it needs to flash the RGB components one at a time, but I need to know the "sequence" time.
In my application, the object needs to be moving. Not quickly, but it will pass by the sensor in 0.5 to 1 second. Ideally, the object's color will then be matched to a database of colors (similar to the attached color-match program). The frequency of reading will also be 1-2 seconds. Ambient light will not be an issue because the object will be rolling in a tube with no light infiltration. The object will also be less than 1/4" away from the sensor.
Thoughts?
Thoughts?
http://www.parallax.com/Portals/0/Downloads/docs/prod/sens/28380-TSL12T-TSL13T-D.pdf
