Shared Memory Question — Parallax Forums
worthyamherstworthyamherst Posts: 46
edited 2011-07-19 09:48 in Propeller 1
How can I access the shared memory on the Propeller. I am receiving Ping))) data from a basic stamp using an XBee. I can show the received data on the Serial Terminal, I am just wondering how I can store the data as a variable or something in the HUB.
    edited 2011-07-19 08:47
    whenever you are coding in SPIN the HUB-RAM is used to store your code and all variables.
    you have to use the fullduplexserial-object to receive serial data. Please provide more details of what you want to do and how far you got
    with the code on the propeller
    keep the questions coming
    best regards
    Stefan
  • worthyamherstworthyamherst Posts: 46
    edited 2011-07-19 08:54
    CON
    'ClkFreq: 80 Mhz
    _XINFREQ = 5_000_000 'Adjust the frequency
    _CLKMODE = XTAL1 + PLL16X 'Adjust the frequency
    rx = 25
    tx = 27
    baudRate = 9600
    polarity = 1
    bits = 8
    OBJ
    bs : "BS2_Functions" 'Basic Stamp 2 library
    VAR
    byte number
    PUB start
    BS.start(31, 30)
    repeat
    number := BS.serin_char(rx, baudRate, polarity, bits) 'receive from BS; k
    BS.serout_dec(30, number, baudRate, 1, 8) 'show data received on screen
    BS.Debug_Char(13)
    waitcnt(clkfreq/2 + cnt) '0.5 sec pause
    This is the spin code we have to receive the Ping))) Data. I guess my question is if "number" is my variable that I can then send out. Is the variable automatically stored in the Hub? Can I transmit the variable from another cog? And thanks for the help. I am very new to the propeller and spin.
  • JonnyMacJonnyMac Posts: 9,788
    If you store the value in a global variable defined by your top object it will be in the hub. Spin methods (even in there own cogs) will be able to see this variable. If you want a PASM cog to have access to the variable you will need to pass the variable's address to that cog.
