My L298 Become hot....
pusink
I'm using L298 to control 2 dc motor (tamiya), but my l298 become hot. Any tips to reduce or eliminate the problem??
thank you.
thank you.
The chip getting warm might be normal for your application. Are you using a chip version of the L298 that has a tab for a heat sink? Some of these have a heat sink tab for a reason.
For example, look at the heat sink screwed to the L298 in this product:
http://www.sparkfun.com/products/9670
http://www.pololu.com/catalog/product/1117
-- Gordon
http://www.sparkfun.com/products/8589
PS.. You will also have a slightly less output voltage due to the voltage drop of the diode.
Rav - how so?
A resistor would do what you said.... not a diode. Granted, a very large resistor, but it would work..... A diode would voltage drop and flow all the current until it smokes at >1A (theoretically)
Isn't a L298 a chopper drive?? If so, you have your current sense set wrong (I think)... otherwise, there ARE chopper IC's available that would more efficiently control power. If you can't find one to handle that low a voltage, there are chopper circuits available all over the net. CNC world, and the like document them.
Edit: Uh, that's CNC "ZONE" not world.
I'm not "for it", I'm not advocating, but it can be done.
( + the heatsinking, too.)
Granted, hopefully the motors won't be stalled often or for long, but under nominal load you could reasonably expect a draw of 1.5 amps @ 3v, and that'll make an L298 pretty hot.
Like I said, the best solution is to spend a couple of bucks and buy replacement motors that consume no more than 0.8A at stall, and operate at 6-12 volts. Considering the L298 wants to see no less than 2.3v for its input HIGH voltage, and the motor supply should be no less than 2.5v over that, a 6+ volt supply for the motors is more ideal.
-- Gordon
Is it a problem - or in other words how hot and is it dissipating more power than its designed for (given the heatsinking present)? The package can dissipate 25W with efficient heatsinking which is more than its transistors are rated to generate.
Note that the L298 is not efficient at low voltages as its output Darlingtons together drop 2.5V (3.3V worst case) at 1A and 3.7V (5V worst case) at 2A. I wouldn't recommend it for less that 24V supply for this reason. Its certainly not designed for 6V supply.
It may be the case that you need a better motor controller with MOSFET H-bridges.
Really,...
I'm sorry, but what's the top end on that with a 3V motor? 24V, 50V, 100V?
[You know that if I don't insist on the logical extreme in the theoretical that somebody will "mis-read" and expect the logical extreme in the physical.]
This Mabuchi over-volts thing was addressed recently in the following thread/subject -- http://forums.parallax.com/showthread.php?132762-Mabuchi-Motors-voltage-greater-than-3v&highlight=mabuchi
There's on off-site link to a report of Mabuchi over-volts therein -- http://www.pololu.com/docs/0J11/all
If it is still hot,look at the data sheet of your motor and check how much its' stall current.
You may feel if its stall current is more than 2A,it cannot be driven by l298 IC.You will be able to drive the motor by connecting channel A with channel B.
Here is the link to my design
http://code.google.com/p/fritzing/issues/detail?id=875
Sure, the Tamiya plastic kits often comes with a sad 3V motor, but they also have such beasties as the 540 series.
Proper voltage range: 7.2-8.4V
RPM at best efficiency: 14500rpm(7.2V)
Toque at best efficiency: 255g.cm(7.2V)
Current consumption at best efficiency: 7.9A(7.2V)
http://www.rcmart.com/tamiya-53689-540j-motor-p-16068.html?cPath=1560_948
any bets as to how long a L298 would last?
