Anyone noticed the Prop Tool is crashing at start up?
I have been having problems with start up of the Propeller tool in Windows and was wondering if others have had the same problem (solution would be good too). I was running version 1.2.7(R2) at home and installed 1.3 and it worked again. At work I tried the same thing but uninstalled version 1.2.7(R2) first and I still get the same crash with the ever so helpful MS report showing up.
Any suggestions?
Any suggestions?
Sorry for the fuss, it should have been the first thing I did after upgrading.
You could try setting the compatibility mode. That's how I worded around the shutdown problem with v1.2.7 on my Windows Vista machine. Right-click on the Prop tool icon, click on "Properties", select the "Compatibility" tab, and select one of the compatibility modes. It might fix the problem.
EDIT: I was editing my comment while you were posting your fix. Glad the reboot resolved the issue.
