Pin assignment question - coupling one port to another — Parallax Forums
Don MDon M Posts: 1,654
edited 2011-07-17 22:32 in Propeller 1
What is the proper syntax to assign (couple) one port (pin) to another?
Is it outa[16] := outa[23] ?
I can't get it to work.
Thanks.
  • JonnyMacJonnyMac Posts: 9,841
    edited 2011-07-17 21:27
    If P23 is an input you'll want to use
    outa[16] := ina[23]
    You need to make sure P16 is in output mode, too.
  • Don MDon M Posts: 1,654
    edited 2011-07-17 21:31
    Thanks Jon
    Note that this doesn't really "couple" one pin to another. It just copies the current state of P23 to P16. You have to repeat this statement often enough to keep the setting of P23 up to date. How often is enough depends on how quickly the signal on P23 can change and how close you want to keep the state of one pin to another.
