BASIC 2pe Mobo and XBee USB Interface?
Hello,
Does anyone know if I can interface my BASIC 2pe Mobo (# 28300) with an XBee Module (# 32404) that is attached to the XBee USB Adapter Board (# 32400) using only a USB cable?
I know I will need to get an adapter to convert the USB A end to a second mini-b, so that both ends are mini-b (I can't find a cable that is mini-b on both ends).
I also plan to provide external power to the Mobo through the Daughterboard Socket A using the 3-Pin I/O Daughterboard (# 28301).
I know the Mobo and the XBee should be able to communicate via the mini-b interface, so I guess my question is whether the Mobo will supply the XBee module with power through the mini-b interface. Does anyone know if this will be the case? Or do I need to provide the XBee module with its own power? (or a better suggestion all together!? NOTE: I would prefer to avoid using a breadboard or having to use the DB to SIP expanders because space is limited).
Thanks!
Thanks!
Similarly, I can't find anything about powering other devices through that USB port, despite some pretty extensive information about power available through other parts of the Mobo and associated power supply daughterboard. If it does work with the #32404 XBee, don't assume it will also work with an XBee Pro. Those require quite a bit more current, and it's pretty easy to release the magic smoke if you use an XBee Pro without paying attention to current requirements.
