How does the servo work?
I'm a little confused as to how the servo works in the BS2 stamp kit. I (Maybe Incorrectly) assumed that a constant HIGH on the input would result in a constant motion. In fact, I plugged the white control into VDD and only got a slight jerk. So am I to understand that the servo responds only to high/low pulses as opposed to a constant HIGH? And if so, why?
Cheers.....
Cheers.....
Wow, now I'm sorta even more confused! So essentially, there is a "BS2" inside the servo controlling all of this feedback stuff huh ?
Wow, a small microcontroller inside the servo? It must be about the size of that tiny surface mounted led on my Homework board
Cheers....
http://www.parallax.com/Portals/0/Downloads/docs/prod/motors/900-00005StdServo-v2.1.pdf
