DIY External RC Clock?
It is possible to make a cheap simple low-accuracy slow prop external RC clock circuit? ..a poor man's crystal made from a fed resistor-capacitor circuit etc..
(for academic pursuit, making and testing ultimately low power props, and possibly experimenting with cheap "wide band" home-made clocks)
Thanks for your reply.
By calibrate, I mean that you have some way to run the clock for a period of time (several hours at least) and enter in the start and end time as measured by some other (more accurate) clock. The Prop would use that to set a more accurate CLKFREQ value than the assumed value.
Well I would suggest using a CMOS schmidt-trigger inverter such as 74HC14 plus an RC filter, perhaps 100k - 1M resistor and a few hundred pF. The datasheet (see link) has a relaxation oscillator circuit in figure 14.
Note that its power consumption (20uA?) won't match RCSLOW (about 7uA) as far as I can see - there is a graph of current consumption v. input voltage in the datasheet. For better performance two simple CMOS inverters with multiple feedback would be needed I think.
http://www.nxp.com/documents/data_sheet/74HC_HCT14.pdf
