The Logic Converter Mini Board can be used to convert 3V outputs to 5V output or to convert 3V input to a 5V input. Ideal for use when connecting between a 3V Memory Card or Microcontroller. Selectable direction with a jumper mounted on the board.
I ordered a couple since I already planned on ordering some .1" female and male headers.
Futurlec sells them much cheaper than most places...
e.g. a 16 pin female header is $.25 versus $1.43 at Digikey
And it is an excellent form factor for the Propeller 40pin DIP as it is 8 parallel lines that can be arbitarily input or output or in both directions.
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/servo/List/0/SortField/4/ProductID/595/Default.aspx
http://www.futurlec.com/Mini_Logic.shtml
