How to submit a POST or GET
There has been a few posts lately asking how to submit an HTTP POST or GET. I set up a test page so you guys can test your code.
http://www.agaverobotics.com/spinneret/getpost.aspx
IP : PORT = 65.98.8.151:80
Edit: the IP and Port must be set when initializing a W5100 socket
The page will echo Query String and/or Form name values pairs back to the requester.
For those of you using my server code, paste the code block below to your project file and call the GetPost(id) method. Otherwise, the StringSend lines show what info to send to the server.
For POSTing, the important header lines to note are...
For a GET, add ?name=value&name1=value1 to the end requested resource (url).
PUB GetPost(id) | st, size, idx, tempMask
pst.str(string(13,"GET POST!",13))
tempMask := tcpMask
tcpMask := SetTcpSocketMaskById(id, 0)
Socket.Close(id)
pause(delay)
InitializeSocket(id)
pause(delay)
'Get My IP
pst.str(string(13, "Getting Assigned IP ",13))
Socket.Connect(id)
pause(delay)
repeat while !Socket.Connected(id)
pst.str(string(13, "Sending Header ",13))
'spinneret/myip.aspx
'spinneret/datetime.aspx
'/spinneret/getpost.aspx?id=1&test=2
StringSend(id, string("POST /spinneret/getpost.aspx?id=1&test=2 HTTP/1.1", 13, 10))
StringSend(id, string("Keep-Alive: 115", 13, 10))
StringSend(id, string("Host: agaverobotics.com", 13, 10))
StringSend(id, string("Connection: keep-alive", 13, 10))
StringSend(id, string("Content-Type: application/x-www-form-urlencoded", 13, 10))
StringSend(id, string("Content-length: 23", 13, 10, 13, 10))
StringSend(id, string("name=test&submit=Submit"))
repeat until size := Socket.rxTCP(id, @rxdata)
'Find and print the message body
idx := str.MatchPattern(@rxdata, string(13,10,13,10), 0, true)
pst.str(@rxdata+idx+4)
'Reset the socket
Socket.Disconnect(id)
'Reset the tcpMask
tcpMask := tempMask
Content-Type: application/x-www-form-urlencoded Content-length: 23 test&submit=Submit
