Interesting Question
I was taking apart a scientific calculator and I found two flat objects in it. I thought "This might be an LED" and sure enough, when I got home I put a few mA in it and it lit up red. Here's my question: Why was there a LED or an object that acts like a LED in the calculator? It was at a position that you'd never see it light up unless you opened up the calculator, so what is the point of that object being in a calculator?
{just a guess}
I once built a power supply with 188,000 uF of filter capacitance. I put an LED and a resistor on the capacitor board, just to remind me if it still had a charge. You couldn't see it from outside the case.
Bill
It believe it wasn't connected to anything like that and the red light emitted from it was probably too dim for that.
You know, I had never thought about that and that is probably why there was a LED in it.
Yeah, that would sort of kill my theory at least for your calculator. However the HP 6S solar uses a 1.5 volt button cell.
I just did a quick Internet search and this is the model: TI-30X IIS. I could be wrong about a 3 V cell, if anyone knows what cell that model uses please reply.
