BST PROBLEM with view error
Hi
Have a question on how to see the error log on BST 19.3. I do the shift + ctrl+E and only see the file path at the bottom of the IDE. My programming generates many compile errors! I just started with BST so I am probably at fault.
Also is it compatible with Viewport with its non PropTool commands?
Thanks in advance for your help!
Thanks for your quick reply! I think you nailed it but how do I get it back?
Here is a view of the complete IDE.
Figures it would be a Vista issue!! I know, I know I should change to a Linux OS but a little nervous to do that on a laptop.
Any one else have any ideas other then re-installing? I like what BST offers over PropTool and would love to see either work with Catalina.
Thanks for replying!
Looked at the registry under Geometry and mine shows: 27,88,663,848,467,250,1
Does this help?
Thank you so much!! Changing the last number to 100 made it visible again. Could you please explain to me what I just did?
Thanks again!!
Thanks again for your help and guidance...
