Using the 4x20 NewHaven driver with a 2x20 NewHaven
Hey folks!
I have a couple NewHaven 2x20 displays sitting around, and being very sucessfull with the 4x20 using the file in the obex, I wanted to use them up in other projects. I looked at the data sheets, and cannot see much of a difference, other than the 2 lines not being there. I try a simple init, then display baud, and I can't get the 2x20 to do anything. When I short the 2 jumpers, it does the self-test without a problem. And yes, I have tried monkeying with the Display, contrast, all that.
Like the 4x20, I have Vcc connected to the 5v line, Vss to GND, and the serial line to a prop pin. According to the data sheet, the minimum voltage requirement for the serial data line is low enough that it should fire up without any level-shifting.
Here is the pile of stuff that will help anyone ambitious enough to help diagnose this one with me.
4x20:
NHD-0420D3Z-FL-GBW.pdf
2x20
NHD-0220D3Z-FL-GBW.pdf
Obex File (for 4x20):
http://obex.parallax.com/objects/704/
Oh.. and I did the change to the Obex file that anon (cough, cough, was me, not logged in that day) said to do. The LCD.cls works Just fine with the 4x20.
CON '' Clock settings _CLKMODE = XTAL1 +PLL16X _XINFREQ = 5_000_000 LCDPin = 0 ' LCD Seiral Data LCDBaud = 9600 ' LCD Baud Rate VAR OBJ LCD : "Lcd_NHD-0420D3Z-FL-GBW.spin" PUB Main LCD.init(LCDPin, LCDBaud) LCD.setContrast(50) LCD.setBright(8) LCD.dispOn LCD.cls LCD.showbaud
4x20:
2x20
