stepper feedback & voltage measurement
Hey guys.
I would like to get a little feedback from a stepper driven by a bs2 and L293d driver, but i only really need to know when theres too much load on the stepper rotor for it to continue turning...
Does anybody know of a sure-fire method of doing this? I'm acatualy just looking to get a positive logic signal to another IC when the stepper is halted
I haven't actually recieved my steppers yet and am still on LEDs, but i'm assuming that if the rotor shaft is held (against its will) the voltage will rise across the driver pins? I see experiment #28 in the paralax booklet uses an ADC0831 ADC chip to measure voltage across a variable resistor...could I just replace the vss & vdd pins with each side of one set of the driver pins? a schmitt trigger seems a bit overkill and my board is getting populated enough!
You might be able to pick up some kind of transient signal from your non-energized coils as the magnetic rotor moves past them, but that would require some extra circuitry.
Do you have any suggestions?
Higher voltage & current will give you increased holding torque on a stepper, if you dare. Same with energizing more than one coil at a time.
I'm still mad I didn't think of it!
Describe your setup more fully and attach some pics for better help.
Alternatively, you could have several contact switches inside the fingers, so that when one or more switches open or close, you deem contact has been made. You could connect multiple switches in series or parallel, depending on what you're grasping. You could get some inter-finger feedback from something like that. Once you grip something, you need to keep it squeezed to avoid dropping it, so you'll keep the last coil energized, correct?
Finally, you could have a load-sensing motor mount. Mount your stepper motor so that it is free to rotate around its shaft. Spring-load it against a fixed stop. It will try to rotate against the spring force away from the fixed stop as the load increases, and it can trigger one single limit switch at a preset load before the motor stalls. You could also have a spring-loaded inline coupling between your motor and mechanism, but then you'll need slip rings or something.
