Can write/read to PINK, but cannot see on network
Hello,
I have recently bought the PINK development Kit. I was able to see the PINK (connected to my router) on my desktop using the Netburner IPSETUP tool, and set a static IP and changed the baud rate to 2400. I was then able to write and read using a BS2.
Now after a couple days I can no longer access the PINK using the IPSETUP tool. I've tried searching with all fields empty and with the dynamic IP I assigned (and every other possible combination). Interestingly, I can still write and read string and variable data using the STAMP BS2 so it appears to still be working.
I have tried accessing the PINK using the IP address in the "XXX.XXX.XXX.XXX/nb_factory.htm" format in Internet Explorer 8 but it did not work. I tried two other laptops with both a network switch and the "normal" Ethernet cable, and directly from a laptop using the cross-over Ethernet cable with no luck.
I'm glad to be able to write and read variable data but I need to be able to access the PINK from a network for it to be useful.
Any ideas of how to find the PINK on my LAN.
I will post this at the Netburner forum as well but it doesn't seem to have much traffic regarding the PINK
falcon
falcon
It sounds like the PINK is up and running though.
I'm not familiar with it but I tried the arp -a command and did get a result. What should I look for? The IP I set to the PINK did not show in the results. The MAC address on the PINK label did not show in the results either.
The ping resulted in 4 packets sent, 0 packets received.
From my MODEM I checked the "DEVICES ON LAN" page and did not find the PINK.
falcon
It sure is strange.
Thanks for your help.
Anyone else have a suggestion as to how to get my network to recognize the PINK?
falcon
First, am I using the right cat 5 cable? Have I tried a different cable, just in case the one had a weak/bad connection somewhere?
Have I tried plugging the cable into a different port on the router?
Have I powered everything off and back on again and retested?
Have I tried hooking the PINK directly to a computer using a crossover cable and seeing if I can access it using IPSETUP?
How old is the PINK? Does it have the latest firmware? (Win 7 and older PINKs have some issues that are resolved by firmware upgrades.)
Do I have another PINK that I can swap in and try setting up again? I have popped two PINKs due to power line surges (both were in remote locations during lightening storms.)
If you connect the PINK to a computer via a crossover cat5 cable and STILL can't see it, I'd start suspecting a hardware failure on the PINK... Let me know what of these you have done and if anything was helpful.
Good luck!
Dave
I appreciate the advice. I’m not past doing dumb things so any suggestions are welcome.
I did try a different router port and a power reset but no luck.
I switched to my laptop (which is not on my network) using the red cross-over cable but luck.
I just received the PINK from Netburner last week so I assume it shipped with the latest firmware. I’ll have to check that.
I have only the one PINK.
I finally did get the PINK to show using IPSETUP. I restarted the router and the PINK showed up. I did discover that the range of IP addresses assigned by my router’s DHCP function overlapped the one I assigned tothe PINK, so I changed that. I only have a few items without static IP’s set so that shouldn't cause a problem.
falcon
Dave
I have this working now but am having issues with seeing strings on a web page, but I will start a new thread for that.
BTW, how do I change this to SOLVED? I looked around but could find it.
falcon
Dave
