problems installing propellent v1.3
I am trying to install propellent v1.3 from the parallax website on my PC and I keep getting an error message that I am missing a required parameter.
It states: Propellent.exe requires 'propeller_file' parameter.
This seems like a pretty simple bug to fix but I dont know where to look for this file. Is this something that should have been installed with the propeller tool?
I am trying to use the Xbee transceivers to soft load the propeller and the application note says that I need to have the propellent installed. If I dont actually need the propellent then that would be the easiest way to solve this problem, but I am guessing that is not the case.
If your connected to one of the propeller development boards type propellent /id
Or is XBEE app really wanting propellent.dll in the path so it can find it and use it.
Tom
It is saying that it cant find propellent. I downloaded the folder from parallax and when I clicked on the propellent.exe to install it I received that error message. There is no part of propellent that is installed on my computer, only the propellent v1.3 folder that contains the driver, readme file, and so on...
Normally you will get that error when you have not extracted all the files from the zip file into a new folder. You can not run the install from inside the zipped file. Make sense?
That will make it easy for the XBee loader to find it.
