So i need a little help
Im working with the discontinued tranceiver receiver pair, one on a basic stamp and the other on a propeller board. For the stamp im simply using the sample code for the transmitter given, but im have a hard time getting the transmitter to sync with the receiver.
This si the sample code for the transmitter:
the coding im using on the propeller for the receiver is:
So, any suggestions or hints or programming fixing, becaus eim currently only picking up static on the receiver
' -----[ I/O Definitions ]------------------------------------------------- Tx PIN 1 ' Transmitter (27981)DATA pin ' -----[ Constants ]------------------------------------------------------- EOM CON 255 ' Value to signal end-of-message #SELECT $STAMP ' Select Baud constants #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T4800 CON 188 T9600 CON 84 T19K2 CON 32 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T4800 CON 500 T9600 CON 240 T19K2 CON 110 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T4800 CON 813 T9600 CON 396 T19K2 CON 188 #ENDSELECT Inverted CON $4000 'Value for inverted serial format Baud CON T9600+inverted '9600 baud, 8,N,1 inverted ' -----[ Variables ]------------------------------------------------------- string VAR Byte(16) 'Array to hold received data idx VAR Word 'Index into message data StrLen VAR Byte 'Length of string received char VAR Byte 'Current character from message cValue VAR Byte 'Holder for CRC calculation crc VAR Word 'Calculate Crc value ' -----[ EEPROM Data ]----------------------------------------------------- Message DATA "Parallax produces our own RF modules from products made by" DATA " the wireless module leader, Linx Technologies.", CR DATA "The Parallax RF modules provide a very easy and low-cost" DATA " method of sending data between microcontrollers", CR DATA "from 500 ft+ line-of-sight (depending on conditions).", CR DATA "This device can be connected to a PC serial port using a" DATA " MAX232 line driver.", CR DATA "The circuit isn't supported by Parallax, but it's possible" DATA " to make this connection with a few dollars of parts.", CR DATA EOM ' -----[ Initialization ]-------------------------------------------------- ' -----[ Program Code ]---------------------------------------------------- LOW Tx 'Initialize transceiver interface DO idx = Message 'Point idx to start of message data DO strLen = 0 'Set string length to zero crc = 0 'Start Crc at zero DO strLen = strLen + 1 READ idx, char 'Read a character from message data idx = idx + 1 'Point to next character in message string(strLen-1) = char 'Put character into string array cValue = char 'Prepare to add char to Crc value GOSUB CalcCRC 'Add cValue to Crc value IF (strLen = 15) OR (char = EOM) THEN EXIT 'Exit loop when ready LOOP 'Keep reading message characters ' Send packet PULSOUT Tx,9600 'Send sync pulse to radio ' Send preample "UUUU!", string length, string data, crc SEROUT Tx, Baud, ["Hello World!", strLen, STR string\strLen, crc.LOWBYTE, crc.HIGHBYTE] PAUSE 100 'Give receiver time to process LOOP WHILE char <> EOM 'Keep sending until EOM character LOOP 'Start all over at the beginning ' -----[ Subroutines ]----------------------------------------------------- ' CRC Checksum Calculation Routine CalcCRC: CValue= crc.HIGHBYTE ^ cValue >> 4 ^ (crc.HIGHBYTE ^ cValue) crc = cValue ^ (cValue << 5) ^ (cValue << 12) ^ (crc << 8) RETURN
CON 'ClkFreq: 80 Mhz _XINFREQ = 5_000_000 'Adjust the frequency _CLKMODE = XTAL1 + PLL16X 'Adjust the frequency rx = 0 baudRate = 2400 polarity = 0 bits = 8 OBJ bs : "BS2_Functions" 'Basic Stamp 2 library VAR byte number PUB start BS.start(31, 30) repeat number := BS.serin_char(rx, baudRate, polarity, bits) 'receive from BS; Tried to use "BS.serin_dec", but didn't work BS.serout_char(30, number, baudRate, 1, 8) 'show data received on screen waitcnt(clkfreq/2 + cnt) '0.5 sec pause
[ code ]
[ /code ]
Remove the spaces.
