Board compairison and Dicision
Hello everyone,
I am trying to decide which BASIC Stamp board I schould buy.
I want to know the difference between the BASIC Stamp Homework Board or the Board Of Education.
I would like to build a fire alarm control panel so I need something that can connect to an LCD display and able to connect to terminals to make pull stations to activeate and sound the alarm. I also would like a system reset and programmable sound codes.
Thanks Alot,
Todd
Thanks Alot,
Todd
The Homework Board has a smaller +5V regulator and the I/O pins have protective series resistors in each lead. For most situations, these don't affect the I/O pin use.
Assume that you will need some external components, particularly if you're going to have more than a few stations. There's a discussion in the StampWorks Manual on using 74HCT165s to provide extra inputs (8 per device).
The biggest difference between the Homework Board and the Board of Education is that the HW has an embedded BS2 standard module, and the BoE can use any of the available 24-pin Parallax modules all of the Basic Stamps, the Javelin Stamp, and the Spin Stamp. There are other differences, such as power regulation, available connectors, etc., but these are more secondary considerations.
You also have other options, such as the carrier boards, as well as the OEM stamp kits. I suggest that you first determine which Stamp module best fits your needs, then picking the best board for the project.
