BS2 stamp not identifying
I purchased a Boebot kit, USB to serial that I assembled at home using a laptop running WinXP. It's my first robot. I had no problems with it.
I purchased a 2nd exact same kit to use for my grandchildren. Now I'm having problems. The stamp won't identify. I'm using a Win Vista laptop this time. The power supply, 4 2-AA batteries seem fine as do all the connections. The light on the USB adapter and the green led on the board all light up.
Any suggestions? My grandkids, and me, are disappointed.
Bill
Bill
1) No power. The fact that the green LED on the board lights up helps, but it will light even if the supply voltage is too low for the Stamp to work. The USB LEDs are powered by the USB bus, so they'll light even if there's no power to the rest of the board. Try fresh batteries or an AC adapter.
2) No serial connection. The fact that the USB adapter light comes on helps, but you might still have problems with the USB cable. Try another cable if you haven't already.
3) Serial driver on the PC not working. Try downloading a fresh copy of the USB driver from FTDI (http://www.ftdichip.com/FTDrivers.htm). Make sure you have the Vista version. Make sure you don't have the BoeBot plugged into the PC while you install the driver. This is true for any USB driver installation unless the documentation says otherwise.
I've now tried 2 Vista machines and 1 MacBook Pro with the Mac drivers installed, Parallels running Win7 and the Win drivers installed. All 3 machines have the same results.
Any suggestions?
Otherwise, I guess I'll have to take it home and try it on my WinXP machine that works with the BoeBot I built as a trial before coming here. Bummer! I really wanted to introduce my grandkids to robotics, electronics and programming.
P.S. I've seen cheap new battery's not work with the Boe and my digital camera, and some other stuff using motors/servos. Not real good in a mag-lite either.
This is only my 2nd robot. The 1st was a BoeBot that I practiced on before going to see my grandkids. The 2 oldest are old enough to be interested and learn some tech.
I'm no electronics techie, just a software developer that in times past, projects involved some hands-on hardware such as wire wrapping pins, replacing, or modifying boards, etc. Never did like that hardware side of things. Too mysterious compared to software.
B L
