ds1620 temp sensor problem — Parallax Forums
krazyideaskrazyideas Posts: 119
edited 2011-07-08 08:43 in Accessories
I am useing the DS1620 to read some tempatures on some mosfets, so I will not blow up the mosfets.
I have the DS1620 working perfect in my bread board, but when I move it any distance away from the bread board via jumper wires about 24 inches long it will no longer work. I tried putting a 500 ohm in place of the 1000ohm but it made no difference.
I walked through all the wires very carefuly and the only difference of working and not working is the leanght of wires between the propellor chip and the DS1620
I'm a beginner programer, and I haven't a clue why this is happening. The leanght of wire is has never affected anything else I have worked on.
  • krazyideaskrazyideas Posts: 119
    edited 2011-07-05 12:43
    I was reading through some other post and they fixed the problem but changeing the power to the DS1620 from 5v (which is what I had) to 3.3v and it fixed there problem. So I just tryed it and it works fine, now. I would still like to know what was going on there though any ideas.
    the spec sheet said it was fine to run the DS1620 with 5 volts.
    Why would it work at 5v close to the propellor but not far away? and why will it work close or far away from the propellor at 3.3v
    edited 2011-07-05 12:50
    how do I get the unsolved stat off my post
    edited 2011-07-05 12:53
    The ds1620 is a 1-wire device and uses a communications protocol where the line is pulled high by the devices. if you have a 5v device being pulled "high" by a 3.3v device it might not work and the further away it is the less likely it will be.
    edited 2011-07-05 13:00
    The DS1620 is sensitive to noise on its power supply line. Try a capacitor of about 1 µF across the 5V supply right at the remote DS1620.
    The DS1620 is an SPI device. Franklin, it is the DS1820 that is one-wire.
    edited 2011-07-06 00:49
    Thanks for the help guys
  • bomberbomber Posts: 297
    To remove the "unsolved" sign, go to the edit tab under your post. Then click Advanced. Next, change the prefix to whatever you prefer ("solved" or "no prefix").
