I need a single 13x6cm PCB done (need sharer)
Hello,
I am in need of a single 13x6cm PCB to be fabricated and was wondering if anyone is interested in giving me some space on their next PCB run.
Anthony
Anthony
I use iteadstudio for prototyping. For 5 of your boards it would be $48 (9.60ea - 15x10cm max size)
If you can sneaky your board into 10x10cm it becomes significantly cheaper - 10 boards for $25. (2.50ea)
Another option is sparkfun's service which is $2.50 per sqin. which would be about $30 per board.
That's not bad. Cheapest I found was $75 for 20 boards. A bit expensive when I only need one.
I am after single sided, single layered, no silkscreen.
It's just a board to house some smd leds to backlight a cutout in a case.
Holes dimensions are not finshed holes, so beware.
Otherwise consider a toner trasfer method of a friend doing boards at home.
For a single (or double) layer if you stick to 0805 form factor or bigger you can have nice results.
I'm not an expert, but I made a couple of small boards and I must confess it is easy. Key point are the proper paper, proper cleaning, and a little bit of care. On the other hand if you are interested it could be great fun, after all you see your board materialising in your hands..
Massimo
However if anyone does them from home ( kitchen sink method
Please let me know
Edit: I would do it myself, but I am out of etchant and live in a small rented apartment at the moment, not exactly conducive of home etching.
