Drawing the PCB
In early days my father (he learnt electronics and basic radio/tv repair in an institute for his hobby) used a Sharpie to draw the circuit lines on the copper clad board before it is dunked in the Ferric Chloride. He drew up an FM/AM radio circuit board, and he still kept it in the storeroom. It looks a bit messy but it did the job perfectly.
Anyone else actually drawn circuit lines without using computer? Or they had been doing that all along during the 70s/80s?
You can do a lot with a french curve and some time...
Now days, it is much easier with the computers, No more trying to rub the bubbles out of a corner,
Just print out a picture and let the light and chemicals mix.
-Tommy
Has anyone turned out good results with the photo type boards?
I saw a video of a board done on Jameco's website. Looks pretty simple, but I don't have a laser printer to print the transparencies.
I read in an instructables article once about feeding the two-layer system to the laminator. That is a pretty brave idea. Or it is a common, casual thing to be done already?
Not sure what you mean John. Are you laminating 2 sheets together for a denser image to expose photo resist, or using a laminator to transfer toner from 2 sheets to a 2 sided PCB?
Toner transfering the artwork to both sides of the PCB. Here's the link: http://myweb.cableone.net/wheedal/pcb.htm
(I just found about "Baconnaise" last week.)
Been drawing traces (draw it, dry it, draw over it, dry it) on copper-clad with a Sharpie for years and years.
Nothing too fancy, it's easier than point-to-pointing power supply front-ends.
That is a nice description and a fairly straight forward procedure for producing 2 sided boards. Aligning the sheets will take a bit of practice. The nice thing with smt is alignment is only critical for the vias and you can use slightly larger thru hole pads for that. Same for thru hole components. They tend to use larger pads as well. The tricky part will be getting enough toner transferred to the copper.
BTW - MG Chemicals has a new product. It is a dry photosensitive film that adheres to the copper. Uses negative for exposure and developing. Around $20.00 for a 12" x 60" roll.
