1.5KB Wear-levelling FLASH filesystem driver...
A guy developing a 8bit homebuild FORTH computer kit just posted about his 1.5KB(C Source code. Assume smaller executable code) FLASH file-system with real wear-levelling.
And yes, he's planning to GPL it all.
(At least that's what he wrote in the Google group posting.)
http://oneweekwonder.blogspot.com/2011/07/flashy-fignition.html
He's working with an AVR chip, but It should be portable to other platforms.
Yes, I'll admit that I own one of his kits. Serial no. 0185 to be exact.
(They're only sold to Europeans as of yet, as he's using PAL composite video for output. )
http://forums.parallax.com/showthread.php?132695-new-amazing-future-computer
The 'future computer' is a pen...
This is about a wear-levelling flash filesystem, created for use on an 8bit computer.
I posted the link because I believe this is something that can be adapted for use with the Propeller, and possibly other Parallax products.
Wear-levelling: the art of spreading the usage evenly across the entire device so that no area ends up 'worn out' before the others.
Did you see a pointer to any of his C source?
http://groups.google.com/group/fignition/browse_thread/thread/228c7a15794ea912#
I believe the FIGnition computer uses I2C for its flash storage...
However, using standard flash for a file system store requires adding the wear leveling code. Some reasons to use non SDcard Flash are for performance (synchronous byte at a time) and improved mechanical reliability (no interconnect).
The problems with wear-leveling Flash tend to grow as the size of the Flash memory grows. So small systems have been done, it is the when you get into larger storage -- say 1GB and beyond -- that problems of bogging down speed arise.
