Some pins constantly high!
Hey guys, I was wondering if i could get some advice...
This is my first delve into the world of bs, and i'm trying to get a stepper running. I've done this with some success but now it seems two of the 4 pins I am using remain high at 5v, even though they are programmed to toggle as the other 2 do, and it did this until 20 minutes ago
I've isolated the chip, supply it with a regulated 9v and I still have the problem. Does this mean the chip, or those pins are buggered? or is there something else I could try...?
Cheers
Cheers
I've tried re-programing but to no avail...
Theres only been 9v supplied to the circuit, and it only seems to be 2 pins held high, the other pins toggle ok, and I was just wondering if it maybe a common problem with stamp processors, as the program loads fine onto a different bs2 chip...
Stampworks (V2) p.150 is Experiment #27: Stepper Motor Control.
There's no variable resistor, that's with the ADC experiments which immediately follow.
Maybe it's the schematic, the depiction/routing of V_dd?
I re-configured that in the attached dwg to sort of disambiguate the layout. V_dd should not be connected to any of the Stamp I/O pins, in the original it should be understood that V_dd runs over/under P4,5,6.
