Speaker for Stamp 2
I have a question about the correct speaker to use for output from the Stamp2. directly powered by the Stamp.. I have been using an 8 Ohm .25 Watt , with very low volume. I have a 10 uF cap inline with input. Works fine, low volume, but works good. Problem is that I have a 50 Ohm, at .1 tenth watt, and I have NO idea as how to use this on the Stamp ,without doing damage to either. The impedence matching is above my head. Can anyone give me a clue as how to use this .1 Watt speaker on the Stamp?? Thanks in advance! John (I am using dual tone generation on the stamp--DTMF---Playing with frequency output, and would like to hear the results.) I am a "Hands On" type of guy---Or "Ears On " in this instance!!!
You could connect a piezo element directly to the Stamp, of course, if you just want it beeping.
