Battery backup
I'm looking for circuit ideas for a battery backup system.
I'm planning to use a propeller and a couple of 5v modules, and I would like to be able to have the system running for a couple of minutes, or maybe less, in case of power failure. It should be able to send an SMS or something similar in case of power failure. I caould also accept to shut down everything else but the micro and the GSM module.
The main supply would be a wall wart.
I think a 9V rechargeable as a backup and a 12V wall wart would be more than enough.
With google I found the following examples:
http://electroschematics.com/6279/battery-backup-circuit/
http://www.mcminnarc.com/helps/charge/charge.html
Are there other, better options? Is this approach viable, or is there a better solution (super cap or anything else)?
Thanks in advance,
Massimo
Thanks in advance,
Massimo
Thanks for the suggestion.
I dismissed it as a non viable solution but reading the docs it looks pretty good, even if maybe overkill.
Funny thing is I searched the forum for similar discussions, with no luck. Now the thread is open in the bottom area there are a lot of suggested threads spot on.
I guess I have to improve my search skills..
Massimo
This looks as the easiest solution, and the cheapest. I don't need to run for a long time from the battery, after all.
I'll make a small setup to see if it fits my needs.
Massimo
Another seller shipping worldwide with the exclusion of Italy.... sometimes contacting the seller and saying I knowingly take the risk works, sometimes not...
Anyway for this use it would be a nice fit...
I assembled a test veroboard, I'll verify if it works and post the results.
Massimo
-Tor
Tor, Italy is considered the country with the worst postal service, so many sellers prefer to avoid shipping to Italy. I live in a quite area, and my delivery rate is 100%, but I agree it is not the same in all places.
Even Parallax in a discussion about USPS unsigned uninsured delivery expressed this kind of reserve about Italy. Other sellers simply state that estimated delivery times do not apply to Italy (Olimex with signed for delivery, just to cite one..).
Usually saying that I now it is risky and accept it unconditionally works, but not always.
Massimo
I live in Mantova, near Verona. I'm really close to Venezia, Milano, the Garda lake and the Alps. Nice thing about Italy is it is so small that almost everything is close.. anyway I'm far away from both Amalfi and Sicilia...
Massimo
I used two diodes, a resitor and a big fat capacitor.
Voltage supply is 9V, and the backup is 4 AA NiMh.
I have to tune the limiting resistance, but it works perfectly.
Massimo
Thanks for the feedback.
Massimo
