PCB shielding questions / CE approval
I have a PCB that I am designing that must pass CE. I was wondering about PCB Board level shielding. Do you connect these shields to chassis ground, digital ground or analog ground? I assume chassis ground but that is my best shot at it. I simply never put a chassis ground on my PCBs so this would be something new.
Also how do you know if you need a board shield (Faraday cage)? I am using the propeller and some sensitive sensors and so far my prototype runs exceptional. Of course CE testing will submit high freq radiation to the unit so you can see why I am leaning towards PCB shielding.
Another issue, If I do in fact need shielding what parts do I need to shield? The entire board? The sensor measuring ICs the propeller?
A link to look at PCB shielding http://www.3gmetalworx.com/products/gallery.php?lang=en
Thanks for reading....
Cell phones have shielding, digital picture frames, monitors, computers all have shielding why would I not need it?
I am intending on using a plastic case with a metal front and rear panel, not that that will mater but just for clarity.
Also chassis ground or digital ground?
Electrical safety and to keep people or animals from being electrocuited, that is a different thing. Called grounding or earthing or double insulated. Here is a bit on this...
(I don't know if this applies to CE?)
http://en.wikipedia.org/wiki/Appliance_classes
