Making the BS2 Object Work
How do I get the BS2 object to work? I got the serial terminal to work with forum help using the Debug: "FullDuplexSerial" object with COM3, Baud 115200. The following using the BS2 object fails to report to the Serial Terminal but causes a slow blink on P15. I have no indication of success of the RCTime command.
If it is not possible to get this to work, is it reasonable to just set the output pin to a fraction between 0 and 1, pause for a moment, then revert to 0 and pause so the ratio of pause1 and pause2 would equal the desired voltage level and the loop frequency would equal 20K?
Thanks.
OBJ
BS2 : "BS2_Functions" 'Create BS2 Object
con
_clkmode = xtal1+pll16x 'For Debug
_clkfreq = 100_000_000 'For Debug
PUB CodeTest | x
BS2.start (31,30) 'Initialize BS2 Object timing, Rx and Tx pins for DEBUG
BS2.PWM_Set(15,4095,12)
repeat
x := BS2.RCTime(13,1)
BS2.Debug_Str(string(13,"Test dec: "))
BS2.Debug_dec(x)
BS2.Debug_Str(string(13,"Test hex: "))
BS2.Debug_hex(x,1)
BS2.Debug_Str(string(13,"Test bin: "))
BS2.Debug_bin(x,12)
BS2.Debug_Str(string(10))
BS2.PWM(15,x,12)
BS2.Pause(1000)
Thanks.
