Question for Mechanical Engineers — Parallax Forums
TonyWaiteTonyWaite Posts: 219
edited 2011-06-28 09:02 in General Discussion
I'm trying to get my head around a purely 'mechanical' issue: the resistance of a fully-tensioned length of 2" pitch ISO1275/216b bush-chain to bending or twisting.
I cannot find any published figures; but do suspect that the bending/torsion resistance is very large compared to the tension within the linear axis of the chain.
Does anyone have any useful pointers?
Thank you,
T o n y
(Yes, there is a Propeller connection! It will be doing all of the data processing, listening to a wireless mesh network, parsing the data, then uplinking it over a 900Mhz connection, then recovering the data and forwarding it at a distant PC. But I've got to sort out the mechanical design before the Guv'nor will let me do the programming...)
    edited 2011-06-28 08:57
    I don't have a number for you, but from a few hundred thousand miles of bicycling & requisite chain maintenance, I can say that the resistance to twisting starts quite high and deteriorates with wear, depending on conditions (lube & cleanliness) and application. For instance, a chain on a multispeed bike that gets shifted (essentially shoved sideways) wears significantly faster than a non-shifted chain on a single-speed or fixed-gear bike.
  • TonyWaiteTonyWaite Posts: 219
    @erco
    Thank you - I had not even begun to consider 'wear and tear'!
    In this application, I want to use the bush-chain to anchor sensors to steel pipelines: so once clamped up there will be no movement as such. But the chain will be good and tight, with special links carrying an M8 bolt-fixing to anchor my sensor.
