PASM multiply questions
I'm deep into working with the vocal tract. So far so good but I'm trying to improve the frication. To do that, I need an unsigned multiply. I suppose that I could use the multiply routine already in it but I don't like using code that I don't understand.
Chip is saving a few longs in HUB memory by building the multiply routine when the program runs. That's cool but it makes it hard to follow. As best as I understand, this is what the multiply routine builds into:
I have always written my multiply routines on other processors with steps like this. MultiplyA is left justified.
This works like long multiplication that I learned in school.
I'm just not following how Chip's routine works but would like to since it appears to use one less instruction per bit.
I must be misunderstanding how it is assembled in COG RAM. Has anyone else figured this one out?
' Multiply ' ' in: t1 = unsigned multiplier (15 top bits used) ' t2 = signed multiplicand (17 top bits used) ' ' out: t1 = 32-bit signed product mult shr t1,#32-15 'position unsigned multiplier sar t2,#15 'position signed multiplicand shl t2,#15-1 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 sar t1,#1 wc if_c add t1,t2 mult_ret ret
shl result shl multiplyA,#1 wc if_c add result,multiplyB
