Prop Powered Vehihicle safty???
Is there a way that some accelerometers, a prop and some servos could be configured to prevent the operator of a 2 wheeled motor vehicle from over correcting when breaking and swerving? What data would be required to figure out if this is plausible.
I am pulling an all nighter as i just had an accident on my scooter and I need to be sure that I did not 'hit my head'. It seems a good way to spend this extra time to try to figure out a way to use the prop to prevent the reason that I am up all night.
A lot of it is just the inherent dangers and limited things you can do on a 2 wheeled system. But there could be some passive things, such as a warning light or specific conditions to cut spark if that would help.
If you wanted something like a warning light. The accelerometer would be easiest if you could overcome any tilting and vibrations that would hinder performance. You could produce a typical g-g diagram while driving and approximate limits for your light. Although if its swerving and braking the quick dynamic/impulse situations probably wont matter.
But you did exactly that:
That implies that when the rider applies the breaks to hard the system is going to back them off automatically. As in the normal understanding of ABS. That implies that there is a strong likely hood of a software or hardware fault causing the brakes to fail.
My experience of ABS on a Citroen BX19GTi is that the one and only time I needed it the damn thing immediately lit up a yellow failure lamp and did not function as advertized. No damage done but it seems that if a major auto builder can't get it right then I'm not about to try it myself.
A better idea would be to trade in the scooter for something a bit more stable. I like the look of those retro style Triumph Bonnevilles:)
Hope the bump on the head is not to bad.
Head is no problem. New knee injury is a 'pain in the leg' as well as a 'pain in the Gluteus'.
