Get to the RESn PIn on the Propeller Proto USB
I'm attempting to program a second Propeller from a Spinneret using Chip's PropellerLoader.spin. I planned to use a Propeller Proto USB board as the second device.
I can't figure out how to tie into the RESn pin on the proto. Before I wire up another prop, I was hoping there might be a relatively easy method of getting to the RESn pin. The reset button?
The top of the connected transistor is another good place.
Don't drive the signal low for extended periods.
I've brought up many times and I'll bring it up again that EVERY one of the Propeller based boards and a lot of the options should have pads for the reset line. Ideally for me just two pads .100" apart with one to ground and the other to the reset line. That way I could easily add a remote reset switch or I can use it for direct wiring instead of going to to side of a surface mount switch...
Robert
