Has anyone used one of the PSP 4.3" lcd's? — Parallax Forums
radialrandyradialrandy Posts: 78
edited 2011-07-01 14:59 in Propeller 1
Curious if theres any code out there yet.
Randy
  • AribaAriba Posts: 2,694
    edited 2011-06-24 16:57
    Are they not similar to Raymans 4.3" LCDs just without Touchscreen and maybe with another pinout?
    Thread: http://forums.parallax.com/showthread.php?115518
    Andy
  • AleAle Posts: 2,363
    edited 2011-06-25 09:16
    They are basically the same, the connector is different: while it is also RGB based some need 3.3 and 5V besides the backlight voltage.
  • RaymanRayman Posts: 15,688
    edited 2011-06-25 19:05
    I think they are very, very similar. I'm tempted to make a board for them, since I'm running out of my "used" screens... I'm still on the fence about it as they are a bit expensive. But, I think there are cheaper clones out there...
    edited 2011-06-25 22:33
    Rayman, here they can be had for some 20 Euro on that auction site (TAS :). But as I said they have 2 VCCs :)
    edited 2011-06-26 09:22
    SparkFun sells them. They also have a touchscreen to go with it.
    SparkFun has datasheets for both devices.
    Duane
  • wjsteelewjsteele Posts: 697
    edited 2011-06-26 20:02
    I am using them with Rayman's code for the 4.3" he sells unmodified. The only difference is the voltage for the BL, if I remember correctly. It does use a different (smaller) connector, however.
    Bill
  • radialrandyradialrandy Posts: 78
    edited 2011-06-27 09:22
    wjsteele wrote: »
    Bill
    Cool. Where can I find Raymans code at. I ordered one of theses lcd's from sprk fun. And I was REALLY hoping someone had some propellor code already for them. Im not that good with programming and I would take me forever to write code to make it work.
    thanks
    Randy
    edited 2011-06-27 09:34
    found Rays code.
    thanks guys
    edited 2011-06-29 06:50
    Now that I think of it... I'm actually using Andy's code... which I think might be a derivative of Ray's code. Andy's used a different backlight scheme that allowed me to set it via a variable.
    Bill
    edited 2011-06-29 19:35
    Where can I find Andy's code?
    edited 2011-06-30 00:16
    In the long thread about Raymans 4.3" LCDs. See Link in post #2 of this thread.
    There is a short version of this thread. See the hint near the end of the long thread.
    I have several drivers posted there, I think Bill uses the graphics driver that works with Chip's graphics.spin.
    Bill
    My code is not a derivate of Raymans driver. My driver is based on Chips VGA bitmap drivers, and Rayman's on Chips VGA tile driver.
    So both are derivates of Chip's work ;-)
    Andy
    Ariba wrote: »
    Ah... I remember now. You're correct, I'm using your Graphics driver. I think because it was full screen (2x pixels.)
    Bill
