Parallel display interface- 4 bit vs 8 bit or serial?
I have an application using a VFD display. The display needs to be updated or refreshed rather quickly showing a number counting.
This is probably a silly question but would an 8 bit interface update quicker than a 4 bit? Would it be twice as fast? Right now I compare it to using PST which updates real quick. Is it possible to achieve speeds comparable to using PST?
How about a serial interface?
Sorry for all the questions...
Thanks.
Don
Thanks.
Don
An 8-bit interface can transfer roughly twice as much data in the same time as a 4-bit interface. There's some additional overhead likely in transferring 8-bit data via a 4-bit interface, but you're talking about digits which would fit into 4 bits naturally if that's the way the specific 4-bit interface would work. PST uses 8-bit serial data (actually 10 bits if you include the start and stop bits).
If you can transfer at 115200 baud on a serial link this means 115200 / 10 bits = 11520 byte per second.
Refreshing 60 times a sceond means that you can transfer 11520 / 60 = 192 bytes at this refreshrate.
How fast do the digits count up?
If you want more specific help please provide a working downloadlink to the datasheet of the displays interface.
(What kind of interface does it have HD44780-controller like LCDs is it similar to 7-segment.display?
keep the questions coming
best regards
Stefan
counting up 23 times per second can't be followed by a human beeing. Do you watch the display with a high-speed slow-motion camera that really every single digit-count has to be shown?
Indeed for car-chrash-tests this could be useful.
From what I saw in the datasheets the controller has a motorola M68-interface (parallel 8 bit, an intel I80-interface parallel 8 bit and a serial interface similar to SPI but to me it seems not HD44780-conform.
You wrote Does this mean you have already tested the display with HD44780-objects for the propeller?
So now I know what is the refreshing-rate. But a 23 times per second counting display is not a selfpurpose. What is it showing?
- microns on a CNC-maschine?
- revolutions of a cable-spindle?
best regards
Stefan
As far as seeing the digits count up one by one- no I can't see them individually but am looking at the comparison of how they appear to count between seeing them on my monitor using PST and on the actual VFD display itself.
Since my last response I have tried another driver from the OBEX - http://obex.parallax.com/objects/667/ in particular the LCD_Nx2 and LCDBase_4Bit_direct_HD44780 objects and they appear to refresh the VFD display much faster but I am still in the middle of testing. My previous object that I was using was this- LCD_16x2_4Bit by Simon Ampleman. That one seems to refresh slow in my testing.
I'll update after further testing.
Thanks everyone for your help and comments.
Don
