BS2 Pulsin to read Domia lite protocol data
I have a BS2 and a 433mhz radio module. My goal is to read some Domia lite data (Home automation protocol) to activate an output.
According to this link http://home2.btconnect.com/totalg/byebye/domialitespecification1.0.pdf at page 5, would use 2 Pulsin consecutively (1 for rising edge and the other for low signal) work ?
I have tried but cannot get it to work. Is the bp2 pulsin command resolution enough ?
Thank you,
Thank you,
Welcome to the Parallax forum
Can you post the whole code that you try-ed so we can try to help you
Here are some more details of what I'm trying to do.
In the image is the data I am trying to acquire with the BS2.It looks +- OK according to the Domia Lite specifications (http://home2.btconnect.com/totalg/byebye/domialitespecification1.0.pdf)
In the PIC, I though I could just mesure the high and low time of the signal like this : But I don't understand the results I get, maybe it's not possible to measure such signal ?
Thank you,
Cyb
and in the data sheet that you have here it dose not tell what they do
Where you see this [%10111101]
In the photo that I posted you where all the bits you are going to have to do something like this you self to talk to this board
I know what they do, I just need to decode the data.
I will decode the data, get a device adress, if the adress is the one of my card; get the command (ON or OFF) and then activate the output...
Thank you,
This will the amount of bits that to read [KLN\12]
