Light Pipes
I placed a PING behind the front panel in my robot and needed a way to project the SMD LED thru the panel.
The PING Protector has a nice little light pipe for that purpose but I didn't want to remove it.
My initial effort involved using some heat shrink tubing with some tiny fiber optic filaments clipped from a Christmas tree. It worked okay but...
I ordered some 3mm White Core Light Pipe from SparkFun and it looks much better. They have it in Clear Core and 1ft or 5ft lengths and also in 6mm diameter.
You could use some heat shrink to connect it to an LED...
It's not really "necessary", but it does give you a visual indicator that the Ping is still operational and that your program isn't "locked up" - not that that's ever happened to me...I mean I've heard stories...;-)
-Matt
